The horn in my '67 Austin MKII quit working some time ago and I finally got around to trying to find out why last night. The fuse is okay and the horn itself seems to be fine as it emits noice when I hooked 12 volts up to it which leaves wiring and the horn switch. I suspect the horn switch but I am not sure a replacement is available. The car seems to have a later steering column from a Morris Mini as the ignition is on the column and the turn signal/dimmer/horn is on a stalk on the right side of the column (it's RHD) plus the center pad thing had a big "M" on it. I saw a switch on MiniMania but it was $105.00 and I am not even sure it is the right application!!
Any ideas?
I thought about getting some of those dual airhorns, is there a way to convert to having the horn switch in the center of the steering wheel if the steering wheel is not set up that way originally?
As always, all of your advice is welcomed.
Thanks in advance.
Any ideas?
Thanks in advance.
