Any suggestions on the best way to remove the rear knuckle cups?
I removed the front knuckle cups with pliers and a flathead screwdriver, but had the front arms out at the time, which made the task a bit easier. The same method isn't working as well on the rear cups with the arms installed. (it is working, but taking far more time and effort) Any advice from the pros to speed up the process? I'll have another go at it tonight after work.
