I need to replace one of my brake rotors due to a sticky situation with a right caliper.
Questions:
1) Are Grooved/Drilled Rotors are worth the added expense for street driving?
2) Is/has anyone run Braided Stainles Flex brake lines? They are supposed to give a firmer pedal and incresed response. Thinking of going with the 5 line kit.
I am thinking about replacing the pads with Greenstuff pads at the same time (replacing rear shoes with regular lining at same time). I've never had the discs hot enough to experiance any brake fade, (in a Mini at least). Which is why I am questioning running the grooved rotors. They look cool and in theory are supposed to deliver increased pad life.
Questions:
