So the suspension is finally all installed, question though. I am running lowered Spax Krypton shox, Ripspeed Hi-Los, and Road Rally Rubber Donuts. I adjusted the Hi-Los shorter then my original cones and there is about a 1/4" space between the big nut and the small nut on my Hi-Lo. This is for the front and rear. Now its all back together, but there is a 5" gap between the top of my tire and the middle of the fender lip. Is it really going to settle 2-3"? I checked everything and it seems to be seated right.
NM, found the info I needed.
