She went limp...
  • She went limp...
    Well I had my displacer blow out on me a while back. Got her swapped out with another one. If that counts for anything. But the right corner is lower than the other side is. What can I do to fix this? I was thinking about fitting a shim. But not sure if that will work. Also it was like this before the original displacer went out.
    Heres a few pics.
    Front Right
    Front Left
    If It counts for anything the rear and both sitting at the same height.
    Thanks
    -Andy
    -Andy
    Start by having both sides pumped up properly to use as a base line. If the RF is still low I'd suspect the RF knuckle joint. What was it like when you replaced the displacer?
      A magic wand and a bottle of viagra if the knuckle joint doesn't fix it.
        Where exactly is the knuckle located and im guessing it involves pumping down the right side to get to it.
        -Andy
          The knuckle joint is a ball and socket arrangement on all four corners. You had to deal with it when you replaced the front displacer. On the front it is a ball fitting into a plastic/nylon-type cup that in turn fits into the upper arm.
          And, yes, you'll have to depressurize the system to get to it.
