I am thinking of purchasing a rebuild kit for my HS4 carb and saw that they have 2 kinds of kits. One for a waxstat carb and one for a non-waxstat carb. What are the differences and how can I tell with mine?
The various Mini manuals (which cover Mk III+) have photos and/or drawings of both.
If you have the Waxstat and are looking to rebuild it, invest in the conversion kit to retro fit the pre-Waxstat set up. More reliable and easier to tune.
Don't know and can't tell for certain from the Burlen manual. It appears that some Minis were using the Waxstat as early as 1975. Not all were (both were used at the same time), and I can't tell when the pre-Waxstat stopped on the HS type carbs.
ah ok thanks, when I see the Mini tomorrow going to go take a glance at the Carb. I found out that the pre-waxstat didnt have a thermostat at the bottom of it and the waxstat did... so there is a black rubber cover on the bottom of the pre-waxstat and a metal thermostat on the waxstat.
