What thrust washer clearance do you guys recommend for a moderately tuned 1275 Cooper S road motor? Engine specs: S thick flange block std bore, AEG 479 std/std crank, 163 head, lightened flywheel/blue diaphragm, SW5 cam, LCB, dual 1 1/4 su's. It will occasionally run at higher RPM's
