My LH turn signals stopped working yesterday on my '96 SPI. RH work fine. All fuses are fine and the 4-way flashers work. It's only if I try to use the stalk. Should I disassemble and check the turn stalk? Any other potential culprits?
LH Turn signals out
When you say that the LH signals don't work, I'm assuming both front and rear bulbs are inop. To eliminate a bad wire, you can insure power at the switch wires using a tester. My guess is that one of the contacts in the turn signal switch might need some persuasion.
Yes, nothing happens when I turn on the LH signals, front or rear. There is power at the turn stalk. I don’t see anything obviously wrong in the stalk. I think it’s euther a he flashed unit, the hazard switch or the stalk itself._______________________________________________
The problem with my turn signal/headlight switch was that there was power right up to the input side of the contact but nothing coming out. It all looked normal. Had to crimp the contacts a bit with some needle nosed pliers as they had loosened up a little over the last 14 years of use. Pretty straightforward, none of that 4 way flasher business to lead me astray.
