The rocker cover gasket I just took off had notches on each side for the bolts on the top side of the engine block. My new gasket doesn’t have these notches. Is it the wrong gasket, do I carefully cut the notches after sticking the gasket to the cover, or do I just tighten it down and have the bolts create the notches?
Rocker cover gasket question
