After removing the deteriorated steering rack rubber gaiters i found traces/chips of nylon/plastic in the grease at the left end of the steering gear assembly. The car is right hand drive. No chips were found at the right end and the rack is centered in the housing. At the left end the rack lays on the bottom of the housing. Haynes recommends a reconditioned unit and does not go into any details. Is there a bushing that has failed? can it be replaced without taking everything apart?
Thanks.
Thanks.
