Followed the Moss Mini instructions on the install of the headlight relay switches, but end result was only the left headlight was working. I connected the relay switches to the two dual bullet connectors that are located at the front of the car below the original horn location. One bullet connector had one blue/white wire going in one side and two blue/white wires coming out the other side. The other connector was the same setup but with blue/red wires. For both I pulled out the wire on the side of the connector that had only one wire and connected that to the relay switch bullet connectors.
Are these not the connectors to tap into for the relay switches? Are there other bullet connectors further upstream that I need to be looking for? Any help would be much appreciated. Thanks.
