This may be a tough one. If the reflector is removable from the headlight you could check out rechroming from an electroplating shop. If it is not there is probably nothing you can do. Except don't drive in the dark. Rechroming is also very expensive.
this Chris,
options:
try the rechroming, I remember there was somebody in Oregon?!!~
Buy new old Carello Lights. , not easy
fit British headlight , would fit.
don t drive in the dark period./ aND IF ONLY HIGH BEAM
I checked UVIRA in Merlin Or. could not connect phone does not worked
also could not finds the webside either
Another Source:
Steves Restoration in Portland or.
they want for 7 inch headlight 150$ ( when made of of Brass)
when steel almost 200 $ a piece.
that's not cheap.
I check further with other options
possible to replace it with new/ used one. if in good shape for that price!!!
