Over the past couple weeks I renewed the rear radius arm bushing & needle bearings. I was installing the RH side last night and on the fwd outboard side there is a bracket secured with 4 bolts. As I was tighening down on of the bolts the weldnut popped of inside the subframe and now spins freely. Any suggestions? Do I need to drop the subframe? Think a rivnut is strong enough? Thanks
Radius Arm Bracket/subframe weld nut
