I have to replace a rod change seal.
I expect that once I get in there I will find it already has an existing metal rod change bushing with rubber seal.
What is the best way to remove the old one to replace? I have heard that you can drill a tiny hole and then put a screw in it so there is something to grab to be able to pull out. It seems there has to be another way.
The last time we ran into this I just left the metal bushing and replaced the seal and the boot and all was well. This time the oil leaks so much I suspect the rubber seal around the metal is damaged.
Thanks!
Thanks!
