rear wheel / stud flange removal
  • rear wheel / stud flange removal
    so the new longer wheel studs won't just tip in , i need to pull the mounting flange out to get the new studs in. I'm down to the "i can see the bearings" but the flange only pulls out/off a couple mm. what is holding it on?
    I just did that exact job. Once you've removed the dust cover, cotter pin and nut, the flange and outer bearing should come out easily using only your hands. At least mine did.
      lil force… got it
      thanks
