What am I doing wrong? I am installing new brake pads on the front of my MKIII mini. I've greased the contact points with high-temp brake grease, new springs are all in the correct position (or at least the position they were in when I took the pads off, the pads are seated properly, I've turned the adjusters to bring the pads in as far as possible, but I still can't get my drums (recently resurfaced) to slip over the pads.
It is possible that my main problem was the fact that I was in the garage at 11:30 pm trying to change out the brakes - I've got 2 kids that burn up most of my "daylight". Is there anyone who knows of something that I could be missing that is causing my problems?
