Hi there. Is there a less expensive replacement for the 02 Sensor than the original?
02 Sensor
After the research I did for my '96 SPI I found the equivalent Bosch 4 wire for mine was part number 15729. From what I understand, you basically need to know the number of wires and the end type (thimble etc)
http://www.boschautoparts.com/oxygen...smartlink.aspx_______________________________________________
