Hey all, I am in the process of replacing the rod-change box in my Mini. I've sourced a brand new unused rod-change housing + rods, so I'm really excited about that.
The mounts on there now (the thread-spool looking ones) are terrible, and the rubber is practically destroyed. I got these new ones from Seven Ent.
http://www.7ent.com/products/rubber-...g-22g2205.html
None of my nuts fit them, even the ones on the existing mounts. I've gone to Tacoma screw, ordered multiple mounts to see if the problem was those mounts specifically, and even tried to run a dye on the mounting threads...
Basically the threads on the mounting studs aren't course thread, and aren't fine thread. Has anyone dealt with this problem before? And if so, can you please let me know how you solved this issue?
Any help would be much appreciated.
