I'm working with Brian S on installing a Mini Mania used lump. MM has blocked off the hose from head to water pump and the pump has no fitting for the bypass.
What's the best course of action? Leave it as is or install a pump with a fitting?
Also, the heater valve position on the head has the bolt holes drilled and tapped but the center hole for the water has never been drilled.
Do we just drill it out?
