control box wiring (bypass)
  • control box wiring (bypass)
    i got the new wiring harness from MM and realize that it is suited for an alternator (good thing, thats what i ordered) the issue is it is also wired for the control box I'm told i don't need anymore, can the CB be bypassed…?
    69 van, 998 A+, alt.
    thanks all
    If the wiring harness is set up for an alternator and you're using an alternator then there won't be any wiring that I can think of to connect to the control box. Of course, I may not understand the question...
      When converting to an alternator it can be a good idea to maintain the control box as a termination point for various wires, depending on what's in your new harness. See Mini Mania's article:
      http://www.minimania.com/Changing_fr...Alternator_721
      I have a converted box I will swap you for your old one if it helps.
        thanks don , this article is spot on, and ill trade certainly trade CB's with you
        206 999 1432 pete
