My turn signals stopped working, but the 4-ways flashers still work. I found a corroded flasher unit on the firewall, no difference when I replaced it. Some research has indicated either there is another flasher unit somewhere under the dash (which I can't find) or there is an issue with the hazard rocker switch through which the turn signals are wired. I just replaced the turn signal stalk and all the other functions on it work (horn & headlight dim switch). The only light that is out is the front right which needs a whole new assembly as the current one fell apart when I removed the lamp to replace it.
Anyone have any ideas where I should look for the fault. Apparently to access the hazard switch, I need to remove the heater. I'm currently trying to figure that out.
Tim
Tim
