Verto Clutch Slave Cylinder
  • Verto Clutch Slave Cylinder
    So, it looks like I have a leaking slave cylinder. What is the liklihood that a seal repair kit will work vs. just replacing the cylinder? Any tips or tricks? I plan to replace the line between the master and slave with a braided line.
    _______________________________________________
    If the cylinder bore is in good shape, no reason that the repair kit shouldn't work.
