Anyone see the latest Mini Mania email featuring Millers "Specially Formulated Classic Mini Oil"? Sounds like its a great formula based on their description. Might this be the ideal Mini oil? ZDDP-additive still required, I assume?
http://www.minimania.com/part/5489JJ...w-50-1l-Bottle
From the webpage:
From the webpage:
• Use in combined engine and gearbox applications
• Engine oil with EP levels of gear protection
Application: Use in installations where the engine and gearbox share the same oil such as original Mini, and gearbox applications specifying an engine oil. The best possible oil for discerning Mini owners.
User Benefits
• Improved engine and gearbox protection versus a normal 20w50 engine oil.
• Longer life for gears, plain bearings and needle/roller bearings
• Improved gear change quality. Longer idler gear life in transverse Mini engines.
Performance Profile API: SF, CD, GL-4 CCMC: CCMC G2
Typical Characteristics SAE Viscosity 20w50
Specific Gravity (at 15°C)0.885
Kinematic Viscosity (at 100°C, cSt) 18.1
Kinematic Viscosity (at 40°C, cSt) 173
Viscosity Index 134
Pour Point (°C) <-15
Flash Point (°C) >200
Cold Crank Viscosity (cP) 9,500
User Benefits
Viscosity Index 134
