From inside the car, four screws. The top two are easy. The bottom screws are turned via holes provided in the parcel shelf. Yes, your heater is in the way.
Peter, as I recall, the instrument pod in your green Inno does not come out like the English built cars. I don't remember for certain, but I believe the mounting screws/bolts come in from the engine side. It shouldn't take long to figure it out.
I'm a bit late to the conversation, but I'll confirm Chuck's recollection that the Inno gauge pod is screwed in from the engine side. Did you find the screws, Peter? Removing them is easy. Getting them back was a bit more difficult, but easily done with two people, one to line up the cluster inside the car while the other puts the screws in.
