Adjusting e-brake?
  • Adjusting e-brake?
    How do I adjust the e-brake on the brakes side? The handle clicks all the way up but does not hold the car it will roll backwards.
    1971 mini Clubman Turbo
    1991 Black German mini
    2007 Jeep Wrangler
    Covered in your workshop manual.
    Technically, the hand brake is not adjusted at the rear brakes, only at the handle, and the adjustment at the handle is only done after the rear brakes have been checked to make sure they are assembled correctly (seldom do I find this the case), in good shape, and adjusted correctly.
