Draining the coolant seems pretty straight forward but I came across a little problem. The screw that is holding on the clamp at the bottom of the radiator is rusted. Cant turn it with a screwdriver because it just bends the head, same thing with a ratchet. Is there an easy way around this short from pulling the radiator?
Coolant Drain
