I'm in the midst of installing a complete new factory exhaust system (1-piece two box style) on a late Mk III 998 and am looking for some reference photos of the correct location for the exhaust differential bracket.
The prior system was "custom made" bodged-up junk that did not even have a bracket, so I'm not sure were on the transmission it mounts? As a result of a number of longstanding oil leaks, there's a lot of built up oily crud underneath the backside of the engine/trans/tunnel area and that is also hiding any obvious studs/mounting holes.
Though not correct, the shot below is the closest thing I've found with Google images. It's an LCB equipped car.
Andrew
1098 LCB downpipe bracket position
Andrew
