my alternator light has been faintly glowing lately(when the engine is running). It seems to fade as rpm increases. The fan belt is tight, the battery isnt very old, am I looking at replacing my alternator in the near future?
glowing red light
You may have an alternator problem. You may also have a problem with the connections to the alternator. Make sure the connections in the alternator are clean and shiney and the same at the other end of the wires. The smaller brown wire on the alternator bundle is the voltage sense wire and I think it could cause the problem you're seeing. Make sure everything is clean before you buy an alternator. You may be surprised to find that you can get a rebuilt unit at your local parts store.
I second that! Some times the boot has been repainted and the grounding connection for the bat. cable is not cleaned befor reconnecting the cable. Witch causes the entire system to ground through the threads of the mounting bolt."remember, in this country, they drive on the wrong side of the road"
The more I think of it, if the light fades and surges consistantly with rpm, then it's almost always the voltage output from the charging system...............................maybe lol."remember, in this country, they drive on the wrong side of the road"
