Thank everyone for helping with my signal dilemma last year, much help. Finally tracked a broken ground a mouse had chewed after making a nice little nest out of firewall foam.
Refilled the wiring with Lucas Smoke, and I'm good to go.
Now my clutch master cylinder is bad however.....
Did you know one of the master cylinder nuts is buried under the reservoir, and against the firewall? what engineer thought this was a good idea? They should be flogged with braided hydraulic cable until they repent.
I did figure out that the distributor wrench I used on my chevy 350's works like a champ for this perticular nut the 1/2 inch end works just fine.
If you ever change your clutch master cyl. buy a cheap chevy distributor tool, it'll be money well spent.
Greg
Greg
