As discussed at last night's meeting, I've invited those that might be interested to come by when I'm working on Minis. Drop in and observe, or get your hands dirty, depending upon what's happening at the time. I'll post upcoming jobs, but realize schedules change from day-to-day.
Mini work usually takes place during the week from about 1:00 until 5:00. On the week ends it's usually from 10 am until 5:00 with a lunch break early rather than late.
Upcoming:
Thu 5/20: Reinstall an estate fuel tank (horrible job when the replacement tanks don't fit very well!). Get the car running (quick job) and try to figure out why it runs "OK", but not as well as it should.
Fri 5/21: Finish up anything left over from 5/20. Then do an oil and filter change on a Rover Tartan, automatic, with air conditioning. (The process on the automatic is quite different than on cars with a standard gearbox.) Lube the chassis. Check the brakes. and a couple other odds and ends. Then make note of all the water hoses to figure out what to order so that they can be changed.
Sat/Sun 5/22 and 23: Finish anything left over from 5/21. Then replace badly worn front and rear rubber cones with coil springs and adjustable trumpets (aka "hi/los"). Replace shocks. Check alignment. This on a Cabriolet SPi.
Upcoming: Pull an engine out of a Mk II Cooper S. Rebuild the differential and convert the incorrect yoke-type differential back to Hardy Spicer. Replace the engine. Rebuild dual HS2s and install on the engine in place of the HIF type on the car.
Upcoming:
